How to connect my roku to my samsung blu ray player home theater
reenter21
I connected my roku smart tv to my digital blu ray player samsung theater but it doesnt out put the sound like it should.
"like it should" means?
If i doesn't sound correct when you play a disc then the problem is inside the HTS. If it sound fine with the disc then what is the problem with the TV?
No sound?
Bad sound?
No surround sound?
Check the audio settings on the TV. Change the surround mode on the HTS. Each Roku channel may put out different audio so may need a different setting,
Is the HTS connected so it gets digital audio from the TV?
