(At the start I'm sorry for my english language)
Hi, I have a question about controlling the fans by the motherboard. Well, in Dark Base 900 rev. 2 there is a PCB to control the fans on the back. I connected there every fans I have in computer case (except cpu of course). So in front of case there is a switch left right to change fan speed, PCB has switch to change between silent and performance but there is also option that motherboard can automatically select fan speed. To make this I have to connect PWM fan controller from pcb to motherboard and switch it to the left but here is the problem. I have MSI Z170A Gaming M3 and I don't know where to connect PWM Fan Controller from PCB to motherboard also if I turn switch to the left fans are spinning slower... I mean if I set switch up to performance mode on PCB it is 800-1600 and silent to the bottom 400-1040. In manual of case is written, If you want that your motherboard will be selecting rpm automatically switch fan controller in front to the left, so I should move pcb switch to the middle and push fan controller in front to the left?
I found manual page to fan controller in my motherboard https://www.manualslib.com/manual/1201339/Msi-Z170a-Gaming-M3.html?page=32 Should I connect it to SysFan 1 2 3 or Cpu2?
I'm really sorry if you cant get something of that but english isn't my native language, I will try to explain more details in comments if it's necessary
Thanks for the help!
