Question How to connect Rgb casing fans Led cable to LED button on the casing?
Jul 28, 2022
18
I have a LED button beside the reset button on the casing.
How can i connect the fans' rgb lights cables to the LED button so i can turn them on/off?
Casing = 1st player X7
Motherboard = Gigabyte B660m AC DDR4
Map out the necessary cable connections and pin outs.
You must be careful because there may be proprietary pin outs, cables, etc. involved.
You will need to reference the applicable User Guides/Manuals for the case, the motherboard, and the fans.
As well as for any other RGB lights that are installed.
This case with the LED button being the second one up from the bottom?
https://www.1stplayer.com/productdetails/id/126.html
[Note: The User Manual link would not open at all for me.]
