Question How to connect rgb fan to msi mag codex 5 10th, without rgb header
Sep 6, 2022
7
Hi everyone,
I have a msi computer, more precisely a mag codex 5 10 th with an i5 1040f cpu and a Msi h410 m a pro motherboard , my computer has 2 led strips connected orginaly, unfortunately I searched the entire internet and did not find out how to connect the rgb fans, so that everything with each other connected in the mystic light system, my motherboard does not have a rgb connector and the strips can be controlled from the application level,
You have a single RGB and a single ARGB header on the motherboard. The RGB is denoted as JRGB1 header, while the ARGB is denoted with JARINBOW1 header. Can you parse a link to the fans you've got in your hands?
I'm just wondering how the led strips are connected, since they are not connected to these connectors, because they are simply not there
