Hello, I recently bought a Gigabyte B450M DS3H motherboard and it comes with a RGB Header
and I want to buy the MasterBox MB500 case from Cooler Master : http://www.coolermaster.com/case/mid-tower/masterbox-mb500/
but I don't know if the RGB connection of the fans goes into that RGB header in my motherboard.
The mobo specs says: 1 x CPU cooler LED strip/RGB LED strip header. I don't know if that can also be used for the rgb of the fans.
The case model I can buy is the one without the RGB Controller. Can I just simply chain up the RGB connections of the fans and then connect into my motherboard the remaining female rgb connector?
mobo: https://www.gigabyte.com/Motherboard/B450M-DS3H-rev-10#kf
Thanks
Thanks
