how to connect wires of different color from ps/2 to usb??
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hey guys, I'm having a very hard time trying to connect this cr*p, I want to use my old keyboard but this had a ps/2 port and my motherboard doesn't t have one,
I made the mistake to cut the cable and don't use an adaptor... but anyways.. this is what i have now:
USB: white, black, green and red.
Keyboard's cable: yellow, brown, red and white.
Please help me because I have no idea how to connect them, I've tried several times in different ways.. but it doesn't work.
Found this through some quick googling, it should solve your issue
If you have num lock/scroll lock indicators on your keyboard use those to determine when you have the power and the ground set correctly, that way you only have to try two wires at a time, once you have those two it should be easy to find the orientation for data and clock
Thanks dude, unfortunately this has no solution, I tried what you said and more but as I read in other forum, i guess is not possible to do it without a converter.
