How to control multiple pwm fans with one motherboard fan connector?
Thomas-18
30
Probably the simplest way would be to use a 4 pin PWM splitter 3 to 1 (example: https://www.amazon.com/Phobya-3-Way-Splitter-Single-Connection/dp/B004CLFOK4). However, that will not let you control each fan separately - they would all run at same % speed. If you need to run each fan at different speed, fan hub is the way to go.
