How to Control my water cooler
Rayne1995
70
So I have the http://www.newegg.com/Product/Product.aspx?Item=N82E16835106253
And I'm just wondering how too control noise is there any thing I can do about the Pump speed cause I have the Asus Crosshair V Formula-Z and currently have the fans connected to the CPU_FAN and the pump to the CPU_OPT. Now in fan xpert I can Control the fan speed but not the pump. Pump speed is always around 1844 RPM. Now on amazon (Maybe it's wrong) But the pump speed is 2900+-150 RPM supposedly. Also the Fan speed is 1000-2000 rpm but i can never hit 2000rpm hell not even 1900 so whats the problem.
I commenter on another thread about this. The manual for my h55 says plug pump into cpu fan but then it will vary (unless locked through software). I then read plug pump into psu for always on.
Edit: I use a y split to take power from PSU and send rpm to spare mobo header so cab monitor pump speed and alarm if it stops.
