How to correct a problem that when i press shift 2 it comes to be not @
akabhi25
Hello,
if i press sift + 2 then it come " instead @ and if i press shift + " then it comes @ instead "
now how to correct this
Hi
It looks as if you have keyboard setting which does not match your country keyboard layout
Looks possibly set to UK instead of USA
If you are using Windows you get to 'Keyboard Settings' via Control Panel
does shift + 3 displays £ and shift + ' shows @ then UK keyboard settings [hjkl;'#] [shift + HJKL😡~]
regards
Mike Barnes
