Thilak_1 :
how to create 5 partitions, is not allowing me to create more than 3.
You can have only limited primary partitions on your computer, but you can have many logical partitions.
Your windows must be on a primary partition, next you can create an extended partition that its capacity is equal total capacity of all of your logical partitions you want to create. Then you can create logical dives in your extended partition.
