How to disable "Remember each folder's view settings" and ..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I want to configure a lot of PCs with the folder view settings like
"Details". I also need to disable "Remember each folder's view settings".
I think this information is stored in Registry in
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Cabine
tState]. The registry key "Settings" contains a lot of hex values. Sorry,
but I cannot find info about what each value represent.
Questions:
1: Do you know how to change folder view to "Details" (by changing registry
or another way that can be automated / scripted)?
2: Where can I find detailed information about what the different values of
the registry key "Settings" means?
Thanks
Harald
Hi Harald,
How to view file list in detail mode permanently (WXP-Pro)
http://snipurl.com/8vtd
These are the keys that remember the setting but do not change with
the settings:
HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\BagMRU
HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\Bags
Another way to do what you want would be to set the view and disable
folder options:
1. In Windows Explorer/Tools/Folder Options/View/clear "Restore
Defaults" and "Reset all Folders".
2. Reboot
3. In Windows Explorer [Not "My Computer"] go to the View Tab and
Reset the options you desire.
4. In Tools/Folder Options, "Do Not" enable "Remember Each Folder's
View Settings".
5. Close the View Tab. Make sure the View is still as you would like
it.
6. Then go to Tools/Folder Options/View/"Apply to All Folders".
Then disable the Folder Options Menu by creating these Registry
Settings:
User Key:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
System Key:
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
Value Name: NoFolderOptions
Data Type: REG_DWORD (DWORD Value)
Value Data: (0 = show options, 1 = hide options)
The icon in Control Panel may have to be disabled also.
You may find this site helpful also.
Doug's Windows 95/98/Me/XP Tweaks and Tips
http://www.dougknox.com/right.htm
Regards,
Bert Kinney [MS-MVP DTS]
http://dts-l.org/
> settings like "Details". I also need to disable "Remember
> hex values. Sorry, but I cannot find info about what each
> value represent.
> Questions:
> changing registry or another way that can be automated /
> scripted)?
> different values of the registry key "Settings" means?
> Thanks
> Harald
Harald,
To disable "Remember each folder's view settings":
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
DWORD ClassicViewState 1
2: Some references:
http://www.microsoft.com/windows2000/techinfo/reskit/en-us/default.asp?url=/windows2000/techinfo/reskit/en-us/w2rkbook/regentry.asp
http://www.microsoft.com/technet/prodtechnol/windowsserver2003/proddocs/deployguide/regentry_overview.asp
http://www.microsoft.com/resources/documentation/windows/2000/server/scriptguide/en-us/sas_pt1_overview.mspx
scriptguide
