Question How to disable scroll wheel when left click is pressed in?
maks kuznia
208
I need my scroll wheel but sometimes I use it accidentally when holding left click. I need some software that can disable the scroll function only when clicking the left mouse button.
Questions: Make and model mouse? What OS are you using?
That said, try the following:
https://support.microsoft.com/en-us...leshooting-various-problems-using-mouse-wheel
Not sure of other immediate solution(s) per se.
Warning
If you have been googling you may have found links similar to the following:
https://superuser.com/questions/731414/how-to-disable-scrollwheel
May or may not be a viable solution but overall any registry editing should be avoided.
Just be forewarned accordingly.
wait, did you read my request? I want to disable the scroll wheel ONLY when the left mouse button is pressed down.
Apologies: went off on a bit of tangent there....
Not aware of any software/utilities per se.
You might be able to run some Powershell (or other script) in the background that monitors mouse button presses and then applies the necessary logic.
I did a quick google and Powershell may be viable. The search criteria also found other products and utilities they may likewise provide the required functionality.
