Hello, my CPU throttles to 1.4 Ghz from the stock 4.0 Ghz while playing a game, I have deactivated every "power save" option in my BIOS (CE6, Cool and Quiet, Turbo Core) and using de AMD overrider I've disabled Turbo Core which (if i'm correct) also disables AMP. The throttling stopped in most games (before the changes it was almost each minute) but after 15-20 min of gameplay it throttled again, so I used MSI Afterburner and HWinfo64 to check my core temps and frequencies and exactly at 68ºC it throttles , so I want to know if there is a way to disable thermal throttling because my BIOS doesn't have an option for that. I've researched and most people says that ~70ºC for FX-8350 is normal on heavy load (80%+ across all cores). I've just got a new cooler (Cooler Master Hyper TX3) and added 1 intake fan and 1 exhaust fan so i don't think it will overheat (I don't do overclock) past 70ºC. I want to exhaust my options before changin the motherboard. Here are my specs:
-Motherboard: ASUS M5A 78L-M LX PLUS
-Proccesor: AMD FX 8350 4.0ghz 8 core
-Ram: Corsair CMZ8GX3M1A1600C10 8GB 1600mhz DDR3
-HDD 1: Seagate 500GB SATA (3Gps) 7200 RPM (System disk)
- HDD 2: 2TB Toshiba SATA (3Gps) 7200 RPM (Games)
- PSU: Cooler Master Silent pro m2 720 80 plus bronze
- GPU Gigabyte GTX 970 Gaming G1
- Case: Corsair Graphite Series 230T Black
- CPU Cooling: Cooler Master Hyper TX3
Thanks in advance!
Thanks in advance!
