[SOLVED] How to dry/clean water trapped between LCDmonitor layers inside
Feb 15, 2020
I accidentally let water got inside between layers of my LCD (LG 27mp68vq) monitor while i was cleaning using wet towel
although i tried to let it dry for a week so it wont messed with electricity
but once i turned it on
this white bright mark pop up,
PIC LINK
i assume and googled it found similar issue it was a water that trapped between layers of my LCD
there's several unsure solved case
  1. disassembly and wipe the water inside (this kinda tricky and i don't want to risk breaking it even more)
  2. let it dry naturally (i doubt this methods will works, even so maybe it will take years? bcs like i said its trapped)
  3. put in rice (how do i put this LCD inside rice bag without letting a rice came thru each hole around the monitor)
  4. hair dryer (i afraid it will melt the internal,breaking even more, or fog?)
the question is,
do i really need to disassemble? which the other methods works fine without disassembling ? or other method?
also , is it fine if i kept using this monitor without making other damage or wait until its fixed?
Thanks before.
2 methods:
Disassembly
Time
Time and letting it dry will almost certainly leave a stain.
Disassembly will probably be more hazardous.
"Rice" won't do anything magical more than time.
2 methods:
Disassembly
Time
so you're suggesting me to just give to professional to dismantle it?
if im afraid to dismantle it by myself and i don't want it to leave a stain if i leave it be
im just curious if theres a way without dismantling but no stain
Latest posts
