Question How to enable smart fans/quiet down fans on MSI
iJohnny
25
So my fans have been annoyingly loud and I was just wondering how I could quiet them down a bit, my model is the MSI GS63 Stealth 8RE
I fully expect that the fans in this laptop and its controller system are all matched and pre-configured to work properly. Two factors can impact the perceived fan noise. If you are doing a lot of high-intensity work with it, the fans will run fast to keep the interior cooled properly, and you do NOT want to slow down the fans by changing their configuration settings. But you should check another factor. It is easy to place a laptop on a soft surface that blocks air flow into its cooling slots without realizing that. This can interfere with cooling and force the fans to work harder. Check to be sure the laptop is on s smooth hard surface that allows good air flow in of out of cooling slots.
