I'm planning on buying 2x16GB of RAM (32GB total) for a new machine that I'm building. It's being built primarily to be a video editing machine but it will also be my general purpose computer. What I'm wondering is if I upgrade my machine in the future with a second set of 2x16GB RAM (64GB total) will I hit a cap or bottleneck with the MHz or timings?
I am still in the process of deciding on what RAM I should use. If I ever upgrade I will try to get identical specs so that I have good odds of it being compatible. So how do I find the limit that my CPU/Motherboard can handle? I have read through Intel's and Gigabyte's official pages but either haven't found it or haven't understood it.
Here are my specs:
CPU: Intel Core i7-9700K Coffee Lake 8-Core 3.6 GHz (4.9 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I79700K Desktop Processor Intel UHD Graphics 630
https://www.newegg.com/core-i7-9th-gen-intel-core-i7-9700k/p/N82E16819117958
https://www.intel.com/content/www/us/en/products/processors/core/i7-processors/i7-9700k.html
https://ark.intel.com/content/www/u...9700k-processor-12m-cache-up-to-4-90-ghz.html
CPU Cooler: Noctua NH-D15S 140mm SSO2 D-Type Premium CPU Cooler, NF-A15 PWM Fans
https://www.newegg.com/p/N82E16835608072
Motherboard: GIGABYTE Z390 AORUS PRO LGA 1151 (300 Series) Intel Z390 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
https://www.newegg.com/p/N82E16813145098
https://www.gigabyte.com/Motherboard/Z390-AORUS-PRO-rev-10/support#support-manual
GPU: SAPPHIRE PULSE Radeon RX 5700 DirectX 12 100417P8GL 8GB 256-Bit GDDR6 PCI Express 4.0 x16 ATX Video Card
https://www.newegg.com/sapphire-radeon-rx-5700-100417p8gl/p/N82E16814202350
PSU: Will be at minimum 30% higher than 97 watts above the final wattage rating of my parts with at least an 80% rating from a brand I can trust.
Memory: 2x16GB to be ran as Dual Channel. I can't imagine needing more RAM than 32GB but I want to stay flexible enough to upgrade.
Storage: 1TB of SSD storage as a boot drive with separate HDD storage added after the system is built.
Here are my specs:
