How to fit a dual slot gpu in a single slot case
Lumberjack_64
118
Hi, I have almost no experience with pc stuff so please don't laugh at me, I wanna buy the evga gtx 750ti dual slot gpu but my case only has single slots,what do I do to fit it? I only have one x16 PCI-e and 3 single slots in my case. Do I cut the card or the case and is there a way withouth cutting.http://imgur.com/MNZAMw5
http://imgur.com/t9j7Slv
http://imgur.com/kOIpwAx
Here r some pics of my case and one random pick of my psu
The slot cover nest to the existing card looks like a punch-out/breakaway type that is actually partially cut from the case. There are slots made on the plate for using a flat blade screwdriver to pry the plate cover off. It may take a little effort to break the little metal bridges between the slot cover and the frame.
