How to fix a loud ps4?
kaden golda
354
My ps4 is a jet engine. I do live in cali san jose and its constantly 90 degrees here so that doesnt help. It sits next to my pc with ample headroom for cooling. What can i do to cool it further? Ive seen people dremmil a he in tbe top and put a 120mm fan there but that disrupts airflow right? Ps, nyko coolers dont work.
The fan on a PS4 is a blower type fan that you often see in laptops.
Cold air is drawn through the back of the PS4 and exhausted out by vents on the front of the Ps4.
Because it works 45 degrees to a normal fan you find in a pc or a tower case for a 120mm fan.
If placed directly in the right position above the blower type fan it forces a higher volume of air down to the blower type fan of the PS4.
The static pressure is in creased in in Cmf is increased greatly.
The faster you can force cold air at a higher speed or flow rate the better the cooling effect is on the Gpu or cpu of the console.
Much like ramping the fan speed up in rpm of a fan fitted to a cpu cooler of a pc.
