How to fix CPU Fan Speed error message
Apr 8, 2018
Hi everyone! I just finished my first pc build and I can definitely say I have a lot to learn. Because of that, I figured this would be the best place to ask my questions!
My build consists of an NZXT s340 Elite, an Asus Strix ROG z270e motherboard, an i7 7700k, 16 Gbs of ram (G.Skillz Trident z rgb 8x2 sticks), an Asus 1050ti OC Edition graphics card, and an NZXT Kraken x62 AIO liquid cooler.
Here’s where I need help: I have a stock NZXT fan connected to the CHA_FAN1 header and an NZXT aer fan connected to CHA_FAN2 header. I then have the 2 fans on the Kraken x62 connected to the AIO_PUMP header, so I have nothing connected to the CPU_FAN or CPU_OPT headers. Upon start-up I’m receiving a message in the BIOS menu that reads as follows: “CPU Fan speed error detected. Ensure that the CPU fan is properly installed on the CPU_FAN header or adjust/disable the Fan Speed Low Limit option in the UEFI BIOS.” My question is, is the way I have my fans configured alright or should I move them around? Thanks! :)
Is the pump powered via molex? If it isn't only the 3pin or 4pin for the pump should be plugged into the AIO pump header. If you have fans plugged into the aio pump header they will run at 100% RPM at all times.
You need to plug a fan into the CPU_FAN header to get rid of that message. One of your radiator fans would be a good idea as it's temps will rise and fall based on CPU temps when plugged into the cpu fan header.
