My laptop: legion y520 15ikBn
So i have been having this issue with my internet for a week
Internet connection slows down for couple minutes every 10 minutes and in games my ping would be around 60 normally then jump to 1000 for a couple of minutes then return to 60 every 10 minutes or less.
Ive checked that the issue is not with my internet itself by using another laptops and it was fine so made sure that the issue was with my laptop not my internet itself then i tried connecting an ethernet and it didn't even work it keeps saying connecting then disappears so i made sure that the issue wasnt with my cable so i used another one and same thing happened and i used the same cable on another laptops and it worked fine so i made sure that the issue was with my laptop then i tried uninstalling and reinstalling the realtek pcie gbe family controller and the wifi driver and it didn't work
Im 100% sure the issue is with my laptop not the cable or the router cuz it is working on all other devices in my house normally
I also tried most of the solutions on the internet and none worked like unistalling drivers and disable and enable the ethernet
i tried some that made ethernet appear connected on my laptop but it worked for few minutes then it stopped working and when i trouble shooted it. it said couldnt configure ip address for my ethernet
So is there a fix for either my wifi connection being so slow every 10 minutes
And
Is there a fix for my ethernet not working ?
Here is my ip config
Wireless LAN adapter Local Area Connection* 8:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Local Area Connection* 11:
Ethernet adapter Ethernet:
Autoconfiguration IPv4 Address. . : 169.254.161.68
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 192.168.1.1
Wireless LAN adapter WiFi:
Link-local IPv6 Address . . . . . : fe80::4d82:2ec3:5699:a792%4
IPv4 Address. . . . . . . . . . . : 192.168.1.5
Subnet Mask . . . . . . . . . . . : 255.255.255.0
And
