I built my first PC and on day 1 the kraken was displaying 40 degrees and running fine. The very next day the display shows nothing and my computer immediately overheats and shuts off. What can I do to fix the cooler so it’s working on my cpu?
Ok so I fixed it....don’t laugh at me but....the sata power wasn’t pushed all the way into the pump 😅 it was pushed in far enough for it to turn on but no enough to give the pump full powerYea I just bought it two days ago. I’m new to this if you couldn’t tell haha
It turns on and fans start going as well. I get and imagine on the display that says temperature but doesn’t give me a reading. Where in bios can I check?
Ok, I did have to take it off and realign it when I was building but I didn’t reapply thermal paste when I did that. When I get home today I’ll take it off my cpu and try replacing it again. Should I put new thermal paste or does it matter?Depends on the bios. Mine shows me the pump speed, so I can see that it's working OK. Before doing that, you should still check that it's mounted correctly on the cpu.
Did you plug all the connections back in correctly?
Do you hear water gurgling and the pump working at all?
When you get back home, do whatever it is that you need to do to ensure that's there's good contact between the waterblock and the CPU.
I don’t hear anything when I start it. Just the fans start up and the lcd display turns on but I don’t hear any water or anything
I currently have it plugged into the AIO pump, should I change it to the cpu fan?
I turned off the cpu fan monitoring to avoid the issue of the bios saying no cpu fan error but the temperature of the cpu in the bios starts out about 40 and gets to 90+ in a few secondsIf there's nothing plugged into the cpu fan header then this could be your problem. The bios will read that there is no cooling system for the cpu and consequently may indicate that your pc is overheating. Then, shutting it down to keep it safe. 😄
Yea I just bought it two days ago. I’m new to this if you couldn’t tell hahaIs your AIO new? .. Hopefully it's OK and you can remedy this issue when you get home. Good luck.![]()
I appreciate your help 😊 I spent a ton of money into this new hobby so I was devastated when it wouldn’t workAs simple as that then. Well done for fixing it. Enjoy your new rig.![]()
