How to fix? Whenever I double click on a picture in my pic..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Whenever I double click on a picture in my pics folder it refuses to open it
up to a bigger window that shows the pic enlarged. I also cant use any of
them as a picture for my desktop..
This is what the window that pops up states.....
" THIS FILE DOES NOT HAVE A PROGRAM ASSOCIATED WITH IT FOR PERFORMING THIS
ACTION. CREATE A ASSOCIATION IN THE FOLDER OPTIONS CONTROL PANEL." Then
it shows the OK button to click on.
What can I do so I can view my photos like I use to???
For which filetype?
Repair image file type associations in Windows XP:
http://windowsxp.mvps.org/imgassofix.htm
Ramesh, Microsoft MVP
Windows XP Shell/User
"cole098" <cole098@discussions.microsoft.com> wrote in message
news😀3072A70-2B37-4F72-8275-E826828DFE14@microsoft.com...
> it
> THIS
> Then
Thanks for responding back.. Its for JPG files.. I tried the software you
suggested to reset to defaulyt and it didnt work.. Any other ideas.. Thanks
fir the help. Joe
"Ramesh, MS-MVP" wrote:
> For which filetype?
> > it
> > THIS
> > Then
>> reset to defaulyt
Did you select JPG, and click the "Repair associations" button ?
Try this from Start, Run:
CMD /C ASSOC .jpg=jpegfile
news:9E54CC74-12C9-449D-99D9-77D42735BDA5@microsoft.com...
> you
> Thanks
> fir the help. Joe
>> For which filetype?
>> > open
>> > it
>> > of
>> > THIS
>> > Then
Thanks so much you fixed it with the code I pasted in RUN. Do you think I
will have other issues with non JPG files ??? Any other codes I can copy
and paste in the RUN line.. Thanks
> >> reset to defaulyt
> > you
> > Thanks
> > fir the help. Joe
> >> For which filetype?
> >> > open
> >> > it
> >> > of
> >> > THIS
> >> > Then
>> Do you think I will have other issues with non JPG files ???
Do you have the same problem viewing other file types?
news:8EC71550-0D27-4EF5-BA0D-705838BB1CB4@microsoft.com...
> I
>> >> reset to defaulyt
>> > you
>> > Thanks
>> > fir the help. Joe
>> >> For which filetype?
>> >> > open
>> >> > it
>> >> > any
>> >> > of
>> >> > PERFORMING
>> >> > THIS
>> >> > Then
Oh never mind.. I found if I open them with paint and then resave them it
somehow converts them over to JPG.. Thanks So much for fixing it.. Joe
> > I
> >> >> reset to defaulyt
> >> > you
> >> > Thanks
> >> > fir the help. Joe
> >> >> For which filetype?
> >> >> > open
> >> >> > it
> >> >> > any
> >> >> > of
> >> >> > PERFORMING
> >> >> > THIS
> >> >> > Then
