Hello, I got a new motherboard today the Gigabyte H310M S2H it is rev 1.2. My CPU is Intel i7-9700K.
After setting it all up, the PC springs to life for a second then turns off immediately, from what I've read it seems like it may be simply down to a BIOS thing. PCPARTPICKER suggests that I require the F12 BIOS for my CPU to work. However, after looking I see no reasonable way to update the BIOS without the computer turned on. I have a spare computer (cpu is not compatible with current mobo) if it helps.
Ultimately I'm trying to ask for advice on the easiest way to go about updating my bios.
I also have no way to check the current BIOS ver but I assume it is lower than the one I require.
