Question How to get analog speaker out from laptop dock with no audio-out (can I do USB-C to analog cable)?
So, I ended up going the "classic" way, wiring audio though KVM.
I got this DAC:
https://www.amazon.com/KOOPAO-Adapt...YYT8/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
It works, sound is a bit muffled and getting some skip/cracks when testing with test music. I woudl not recommend it but will do for MS teams for now.
The bigger surprise was that I had a humm on my speakers after setting this up (on any channel). So, I thought I had a ground loop issue which made re plug cables, power supply,... Even got an audio ground isolator.
It turns out the issue is my backlit Logitech K740 keyboard
https://www.logitech.com/en-us/products/keyboards/k740-backlit-illuminated.920-000914.html
It is caused by the backlit function. If I keep the light at 100% or off no noise. The keyboard dimmer is causing this..
so, yes going all digital probably would be a good idea :)
For now I am still trying to see if there is a fix for USB, e.g. a simple 5v-GND USB filter.
