Hi,
My computer has 2 fans one at the front and one at the back however this is simply not enough to keep my cpu cool. Despite my CPU fan I brought (specs at bottom of page) my CPU still gets incredibly hot to like 70 - 80 degrees when playing the likes of battlefield, dayz and H1Z1. I have two more chassis fan slots on my cpu case both next to each other at the top so I was going to buy 2 more fans to slot in there.
Is there any BETTER alternative to using this http://www.ebuyer.com/515105-6in-tx3-fan-power-splitter-cable-tx3splitter to add more chassis fan slots on to the motherboard? I already have one but I'll need to purchase two more for two more fans and It's going to generate a long link of stupid wires. Is there any better alternative as my motherboard only has 1 chassis fan slot >.< even one of them with more heads or something... I literally can't find anything.
FULL PC SPECS:
Windows 8.1 64bit
MSI R9 280 GAMING 3GB GDDR5 DVI HDMI Dual Mini DisplayPort PCI-E Graphics Card
AMD FX-8350 4GHz Socket AM3+ 8MB Cache Retail Boxed Processor
Carbide Series SPEC-01 BLUE LED Mid Tower Gaming Case
Corsair AF120 LED Blue Quiet Edition High Airflow 120mm Fan
Asus M5A78L-M/USB3 Socket AM3+ 8 Channel HD Audio mATX Motherboard
Corsair CSM 650W Semi Modular 80+ Gold Power Supply
WD 1TB Blue Desktop Drive 3.5" SATA-III 7200RPM 64MB
ASUS DRW-24F1ST Internal DVD±ReWriter 24X - OEM
Corsair 4GB DDR3 1600mhz Vengeance Memory Module CL9 1.5V Non-ECC Unbuffered X 2
Using Cooler Master Hyper 212 EVO CPU Fan Cooler
FULL PC SPECS:
Windows 8.1 64bit
