I came across an old Zenith portable television (model # BT044S) but the thing has no coaxial or RCA composite inputs. The only input that it has (for signal, I figure) is a single blue ringed A/V IN input.
I'm assuming there is some way possible to hook it up to a digital converter box but I'm just not sure what adapter(s) I may need to do so?
There is also an external antenna input on this same device. It already has a built-in telescoping antenna on it but I guess you could add an additional one for better reception. However, I've never seen one that connects via a 3.5mm connection that works for television reception, only radio.
To be honest, once you've introduced the digital converter box that I plan on using here, I would think it would be a moot point anyway as any antenna used would have to be plugged directly into the converter box itself and not the television. Nonetheless, for my own curiosity, I'd still like to know what kind of antenna could have been used in this case.
Thanks all.
Thanks all.
