How to Hook Up Surround Sound to PC
Sad_Trombone
17
I have a PC hooked up to a TV via HDMI. I have a surround sound receiver as well with optical outputs. What would be the best method to get surround sound on the computer?
Specs:
-FC 6300
-GTX 970
-8GB RAM
Optical won't get you surround sound in many cases (you can look up optical audio and surround sound for what can and can't work). Best way is to get a surround sound receiver with HDMI inputs and outputs and use that.
Now, if I do that, do I plug the receiver into my GPU through HDMI? If I do that, how would I get video to my TV?
A receiver should pass through video to the TV, although some cheaper and/or older models do not. Need to check your model.
