[SOLVED] How to i fix my retro-pie joysticks?
Jan 13, 2020
I purchased a two player joystick set for my raspberry pi. Everything worked great a first but now when i press up or down on either joystick all the button leds turn off and sometimes even crashes my raspberry pi. Tried connecting it to my PC and i have the same issue except my PC does not crash when doing this. How do i fix?
Link to joystick set: https://www.amazon.com/Fosiya-Joystick-Controllers-Raspberry-Controller/dp/B07WNNVVXY/ref=sr_1_27?keywords=arcade+joysticks&qid=1578973156&sr=8-27&th=1
It would seem that Vcc is being shorted to ground.
Do your USB ports still work?
Can you isolate it to one controller or the other? (But on both controllers?) Is a cable (button/stick to PCB) plugged in backwards?
You could get a USB tester to measure current when the button is pressed
Worst case, the controller on the PCB got fried somehow 🙁
Reactions: xxrollandxx
