Hello 2 all!
First of all, I am not a hardware guy.
I have GA-G33-DS3R motherboard with SSD and HDD connected. SSD is primary with OS and 250 gb HDD is for other stuff.
The issue is, that recently HDD started to be 100% in use. As soon as I try to run some program from it OR running programs tries to read from it - it becomes 100% in use and everything is slow and bad. And this continues for quite a time even if the file size is small.
My first thoughts were that is is win10 100% disk issue (tried some solutions but didn't help), but I also did some restarts and windows updates and windows wasn't loading after that... After many attempts it loaded up and I realized that Windows doesn't see my HDD disc 🙁
Later, after hibernate and woke up - shows up again, but it is slow upon calling, as usual.
I tried to copy some files from it and copying was very slow as well and was throwing an error something about I/O error.
Managed to copy small files, but for big failed.
So my last idea that it isn't software issue but is hardware issue instead... maybe my HDD is going to die shortly?
Is there any easy way to say if IDE cable (yes I think I have IDE interface for HDD) is faulty or HDD is going to die?
P.S: my PC is quite old (4+ years).
