how to implement multi-IP address, or multi-interface, or ..
peter
3,226
Archived from groups: microsoft.public.win2000.networking,microsoft.public.windowsnt.protocol.tcpip (More info?)
I have only one network adapter, and need to access 2 networks in LAN at the
same time using Windows XP professional. Their IDs look like this
192.168.0.x(255.255.255.0) and 192.168.10.x(255.255.255.0). How can I do
this?
Thanks
Peter
You can add a few IPs to the adapter in TCP properties for your adapter (
Advanced button )
Arkady
"peter" <peter@hotmail.com> wrote in message
news:uUkhQjyEFHA.3780@TK2MSFTNGP09.phx.gbl...
>the same time using Windows XP professional. Their IDs look like this
>this?
> Thanks
> Peter
My case is I connect to one of network using DHCP. I want to connect to
another network using static IP. How should I do?
Thanks
"Arkady Frenkel" <arkadyf@hotmailxdotx.com> wrote in message
news:eawJhd1EFHA.1348@TK2MSFTNGP14.phx.gbl...
> ( Advanced button )
> Arkady
>>this?
>> Thanks
>> Peter
You can buy another cheap Nic for $15 dollars and avoid the whole "twisted"
issue.
Phillip Windell [MCP, MVP, CCNA]
www.wandtv.com
the
> this?
> Thanks
> Peter
Static IP address, enter the addresses as desired.
> issue.
He's asking about adding a second IP# that is not part of the same subnet.
IP#s on a Nic are supposed to be all from the same subnet because all of the
other TCP/IP settings are "global" for the entire Nic and apply to every IP#
running on it. You may get "lucky" if they both happen to be using the same
subnet mask (although I'd still never do it), but if they use a different
mask you are screwed because you can only have one mask per Nic.
www.wandtv.com
"Bob I" <birelan@yahoo.com> wrote in message
news:42136AAB.7040004@yahoo.com...
"twisted"
> > issue.
Correct. But then the OP didn't give much to go on, so that's what he's
left with.
That exactly what property dlg allow you , you can see two tabs : General
( like DHCP ) and second - Alternative Configuration ( for IP direct e.g. )
Arkady
news:%23iA2kP3EFHA.2828@TK2MSFTNGP09.phx.gbl...
> Thanks
>> ( Advanced button )
>> Arkady
>>>this?
>>> Thanks
>>> Peter
Yea, they don't give us much to go on sometimes.
www.wandtv.com
news:42137D1F.2060801@yahoo.com...
> left with.
subnet.
the
IP#
same
different
No, in alternative tab of TCP property dlg you can add additional IP/subnet
masks for multihome computer
Arkady
"Phillip Windell" <@.> wrote in message
news:%23Nbn3ZEFFHA.464@TK2MSFTNGP15.phx.gbl...
> the
> IP#
> same
> www.wandtv.com
> "twisted"
>> > issue.
news:ubw0QgMFFHA.2608@TK2MSFTNGP10.phx.gbl...
IP/subnet
> Arkady
Ah! You're right. Sorry. But I still would avoid it. Running two IP
Networks on the same wire just isnt a very good idea. There should be a law
against it,...it's like a guy wereing a dress or something,...it should be
defined as a "act of terrorism" maybe.
www.wandtv.com
Agree with you , but XP by itself give such opportunity called bridge option
( in Advanced menu of Network connections )
Arkady
news:OJtAwDQFFHA.2564@tk2msftngp13.phx.gbl...
> IP/subnet
>> Arkady
> law
> www.wandtv.com
news:eDa69UyFFHA.3368@TK2MSFTNGP10.phx.gbl...
option
> Arkady
Well, yea,..but that isn't the same thing. That would be two Nics in the
same subnet, not two IP#s from different subnets ont he same Nic. Of course
I don't like this "bridging stuff" they came up with (XP & 2003)
either,...there are too many better ways to do things like that.
www.wandtv.com
