How to install phanteks magnetic led strip, p400s case
edward_61
Commendable
Sep 14, 2016
11
Hey guys,
Never used leds before.
Got the phanteks p400s glass case which comes with phanteks magnetic led strip but the manual doesn't include instructions on how to power it. Also doesn't explain how to power the built in case leds either.
Help is much appreciated.
Last (5th) image in this review shows where the added LED strip connects,
link: https://benchmarkreviews.com/42554/phanteks-eclipse-p400s-tempered-glass-edition-case-review/4/
You can connect your LED strip to the case or if your MoBo has RGB header, you can connect your LED strip directly to the MoBo.
And to power the LEDs, there should be either a SATA or molex connector coming out from front I/O panel that you need to connect to the PSU.
