Jhact Honorable Aug 10, 2013 51 0 10,630 Aug 12, 2014 #1 I often get my mouse cord tangled/caught and have to tug a little to get it out. This has made me die more often in games than you would think. It's also made me annoyed with it. How do I keep the cord from getting caught on stuff?
Solution bgunner Aug 12, 2014 http://www.newegg.com/Product/Product.aspx?Item=N82E16826999077 you wrap your wire around it and it holds it on your desk. there are other styles but this is the simplest.
corroded Splendid Sep 5, 2011 2,859 0 21,960 Aug 12, 2014 #2 Depends on your desk... A simple coat hanger bent to make a loop support would do it... Upvote 0 Downvote
bgunner Judicious Feb 13, 2009 5,153 27 32,540 Aug 12, 2014 Solution #3 http://www.newegg.com/Product/Product.aspx?Item=N82E16826999077 you wrap your wire around it and it holds it on your desk. there are other styles but this is the simplest. Upvote 0 Downvote Solution
Jhact Honorable Aug 10, 2013 51 0 10,630 Aug 12, 2014 #4 I was looking at something like that earlier! I'll check it out! EDIT: It gave me an idea to get a plastic pulley wheel and just put it on an axle-type thing. I may do that. Thanks for the input! Upvote 0 Downvote
boju Titan Ambassador Jul 7, 2008 21,604 2,499 85,890 Aug 12, 2014 #5 bluetack 😀 But i like bgunner's suggestion, noidea something like that even existed. Upvote 0 Downvote
