News How to make a Raspberry Pi Home Air Quality Monitor
Hi!
Thanks so much for this guide! I am a complete newbie and found this very easy to follow.
I have followed the instructions as posted but can't make it run well.
When opening the browser to view the page, this is what appears:
This site can’t be reached
192.168.10.165 refused to connect.
then I get this from the Windows command prompt:
web_1 | Traceback (most recent call last):
web_1 | File "app.py", line 15, in <module>
web_1 | aqm = AirQualityMonitor()
web_1 | File "/code/AirQualityMonitor.py", line 13, in init
web_1 | self.sds = SDS011(port='/dev/ttyUSB0')
web_1 | File "/usr/local/lib/python3.8/site-packages/sds011/sds011.py", line 132, in init
web_1 | self.probe()
web_1 | File "/usr/local/lib/python3.8/site-packages/sds011/sds011.py", line 139, in probe
web_1 | firmware_version_data = self.get_firmware_version()
web_1 | File "/usr/local/lib/python3.8/site-packages/sds011/sds011.py", line 226, in get_firmware_version
web_1 | return self.request(cmd)
web_1 | File "/usr/local/lib/python3.8/site-packages/sds011/sds011.py", line 234, in request
web_1 | resp = self.rx_cmd_resp_queue.get(timeout=10)
web_1 | File "/usr/local/lib/python3.8/queue.py", line 178, in get
web_1 | raise Empty
web_1 | _queue.Empty
I am using an old Raspberry Pi (2011.12) and have installed the latest Raspbian OS.
I am hoping that you can help me out.
Reactions: NJAir
I'm having the same issue - currently running Raspberry Pi 3 (B+) - not headless. Can't navigate to IP address as per the last instruction in the tutorial. Sorry, I'm a noob! Any help would be appreciated. Would love to see the air quality readings!
Hi!
web_1 | raise Empty
Hi!
web_1 | raise Empty
I figured it out - this is an issue that was discussed on Github: https://github.com/rydercalmdown/pi_air_quality_monitor/issues
You have to change the code in a file called "index" to point to your pi's IP address (or removed the IP address entirely and use /api/ instead - that worked for me).
Also, you have to close and restart the script ("make run") a couple of times before it runs correctly.
Eventually this will all work, and you'll be able to navigate to your pi's IP address (port 8000) to see the data.
Reactions: Psyrick
Glad that worked out for you. I have done those indicated at the link but I am still having the same errors as before... Decided to just try running different code instead - apparently plenty available in other sites.
I hope that the people who decided to post this tried to run the code first though 🤷‍♂️
Reactions: NJAir
Yes - plenty available elsewhere. Just finished one version using Adafruit IO and it was relatively trouble free. Enjoying putting these things together!
Reactions: Psyrick
Are you talking about the one from the Raspberry Pi Blog? Yeah, that does look good. Would you mind sharing where I can learn how use Adafruit? I am a total beginner at this and have no idea how to setup Adafruit...
Hey,
When I wanted to make the program going I got an error at the make build step.
ERROR: Exception:
File "/usr/local/lib/python3.8/tarfile.py", line 2292, in utime
os.utime(targetpath, (tarinfo.mtime, tarinfo.mtime))
PermissionError: [Errno 1] Operation not permitted
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 167, in exc_logging_wrapper
status = run_func(*args)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 205, in wrapper
return func(self, options, args)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 339, in run
requirement_set = resolver.resolve(
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 94, in resolve
result = self._result = resolver.resolve(
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/resolvelib/resolvers.py", line 481, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/resolvelib/resolvers.py", line 373, in resolve
failure_causes = self._attempt_to_pin_criterion(name)
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/resolvelib/resolvers.py", line 213, in _attempt_to_pin_criterion
criteria = self._get_updated_criteria(candidate)
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/resolvelib/resolvers.py", line 204, in _get_updated_criteria
self._add_to_criteria(criteria, requirement, parent=candidate)
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/resolvelib/resolvers.py", line 172, in _add_to_criteria
if not criterion.candidates:
File "/usr/local/lib/python3.8/site-packages/pip/vendor/resolvelib/structs.py", line 151, in __bool_
return bool(self._sequence)
File "/usr/local/lib/python3.8/site-packages/pip/internal/resolution/resolvelib/found_candidates.py", line 155, in __bool_
return any(self)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 143, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 47, in _iter_built
candidate = func()
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 215, in _make_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File "/usr/local/lib/python3.8/site-packages/pip/internal/resolution/resolvelib/candidates.py", line 288, in __init_
super().init(
File "/usr/local/lib/python3.8/site-packages/pip/internal/resolution/resolvelib/candidates.py", line 158, in __init_
self.dist = self._prepare()
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 227, in _prepare
dist = self._prepare_distribution()
File "/usr/local/lib/python3.8/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 299, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/operations/prepare.py", line 487, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/operations/prepare.py", line 532, in _prepare_linked_requirement
local_file = unpack_url(
File "/usr/local/lib/python3.8/site-packages/pip/_internal/operations/prepare.py", line 224, in unpack_url
unpack_file(file.path, location, file.content_type)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/utils/unpacking.py", line 247, in unpack_file
untar_file(filename, location)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/utils/unpacking.py", line 222, in untar_file
tar.utime(member, path)
File "/usr/local/lib/python3.8/tarfile.py", line 2294, in utime
raise ExtractError("could not change modification time")
tarfile.ExtractError: could not change modification time
WARNING: You are using pip version 22.0.4; however, version 22.1.2 is available.
You should consider upgrading via the '/usr/local/bin/python -m pip install --upgrade pip' command.
The command '/bin/sh -c pip install -r requirements.txt' returned a non-zero code: 2
ERROR: Service 'web' failed to build : Build failed
make: *** [Makefile:22: build] Error 1
Can anyone help me? That would be awesome I'm a complete newbie.
