Question How to make my front panel led strip pair with 4pin motherboard header?
Aprillion
30
Hello,
In the front panel of my pc case I have a led strip which is paired with a rgb fan in my case.
I want to pair these with my motherboard (Asus rog strix b450) with 4pin rgb header.
The led strip has one 2 pin header that goes to the button to change the rgb program and one 3 pin header that goes to molex which goes to the led power.
The rgb fan I have is connected only by molex but it is still controlled by the rgb program of the led strip 2pin button.
So I could not determine what cables/controllers I need to convert this.
^2pin goes to the button in the back, 3pin goes to photo 2:
^From top to bottom: 1st molex goes to non rgb fan (power only), molex 2 goes to rgb case fan, molex 3 goes to the 3pin header on rgb strip, molex 4 is a “led power” connector without cables.
My first thought was, that the 2 pin would be the cable to convert through a controller to 12v/4pin. But would the rgb case fan connected with molex pick up the same control?
Thanks
