First thing would be to find out just what BSODs are. WhoCrashed https://www.resplendence.com/downloads is a program to help you find them. Once you find exact BSOD you can Google it and can find possible causes and fixes.My guess is either a faulty RAM or a overheating CPU (my GPU has NEVER-EVER reached even 80C). You can know the details about the problems I faced in this thread:
[SOLVED] - Why do games crash randomly and sometimes cause bluescreen on my pc?
Please help me. I've been having a really hard time playing games due to random crashes and blue screen of deaths. :'( Firstly, here's my computer: CPU: Intel core i3 6100 (3.7ghz, dual core) GPU: Nvidia Geforce GTX 1650 (4gb, zotac OC) RAM: 8 GB Corsair Vengeance Lpx DDR4 2400mhz Motherboard...forums.tomshardware.com
[Note: Even though it's marked as solved, it's actually not. I marked it as solved cause there were nowhere to go from there]
If the problems we are facing are similar, we could help each other.
My guess is either a faulty RAM or a overheating CPU (my GPU has NEVER-EVER reached even 80C). You can know the details about the problems I faced in this thread:Ziadul87 - Were you able to sort out your issue? I'm having a similar issue, which I thought was GPU overheating, but now I realize could be something else. So looking for troubleshooting tips.
Is that newly built or already used system/PC ? As all errors point to memory, first thing I would do is to check RAMwho crashed reports:
On Sun 7/12/2020 2:32:32 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\071220-31625-01.dmp
This was probably caused by the following module: hardware.sys (hardware)
Bugcheck code: 0x1A (0x41792, 0xFFFF930121339010, 0x400000000000, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A corrupted PTE has been detected.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hardware.sys .
Google query: hardware.sys MEMORY_MANAGEMENT
On Tue 7/7/2020 1:26:01 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\070720-36140-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1BC810)
Bugcheck code: 0xEF (0xFFFFE40486CCC240, 0x0, 0x0, 0x0)
Error: CRITICAL_PROCESS_DIED
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a critical system process died.
There is a possibility this problem was caused by a virus or other malware.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 7/6/2020 11:54:26 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\070620-34687-01.dmp
Bugcheck code: 0x1A (0x41792, 0xFFFFE03FFFF4E510, 0x400000000000, 0x0)
On Mon 7/6/2020 4:47:06 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\070620-41359-01.dmp
Bugcheck code: 0x1A (0x61941, 0x1B2EA790, 0xD, 0xFFFFA108A0572A00)
The following dump files were found but could not be read. These files may be corrupted:
C:\WINDOWS\Minidump\071020-30375-01.dmp
Thank you for identifying. It's a PC i have been using for ~4 years.Is that newly built or already used system/PC ? As all errors point to memory, first thing I would do is to check RAM
Memtest86+ | The Open-Source Memory Testing Tool
Memtest86+ is an advanced, free, open-source, stand-alone memory tester for 32- and 64-bit computers (UEFI & BIOS supported)www.memtest.org
Couple of things to try with RAM. Take it/them out and put them back in and also make sure that they are in right slots. Also check Virtual memory in windows as well as OS disk, Windows uses disk as virtual memory so if anything is wrong with it, it will report it as problem with RAM.Thank you for identifying. It's a PC i have been using for ~4 years.
I have done memtest and got 5 errors on the first test. (But I never again got any errors). But i went ahead and asked the shop to get my RAM for RMA. Sad thing is, they don't believe in memtest and told me to "recreate" a blue screen in front of them (which is a matter of sheer luck). I failed to create a blue screen and so I couldn't get an RMA. 😕
Another thing, Aida64, Who Crashed also reported overheating issue with my CPU. (It reaches 100°C on FC3)
I have tried all of these and the summary is:Couple of things to try with RAM. Take it/them out and put them back in and also make sure that they are in right slots. Also check Virtual memory in windows as well as OS disk, Windows uses disk as virtual memory so if anything is wrong with it, it will report it as problem with RAM.
Memory controller is in the CPU so if it's really overheating it may present a problem.
My favorite program for temps and other is HWinfo64 https://www.hwinfo.com/download/
How would I do that from a country like Bangladesh? What would be the steps?Try each stick individually, if one stick is bad it may bluescreen much more often allowing you to recreate the error for the shop. Having said that can you RMA the ram direct to the manufacturer? Often ram has a lifetime warranty
Check the manufacturer's website for details of their returns procedure.How would I do that from a country like Bangladesh? What would be the steps?
And also, would they charge me for shipping if the RAM came out to be in perfect condition?
Ok, I'll ask for RMA and see if there's any Corsair RMA Location in my regionCheck the manufacturer's website for details of their returns procedure.
That may be true but then again it is very possible that the error is caused by the ram fault. The best thing to do is to solve the ram issue first and address any remaining issues afterward.I am pretty sure my RAM is faulty but not sure if it's the only problem responsible for my BSODs![]()
Ok. But it may take some time due to lockdownThat may be true but then again it is very possible that the error is caused by the ram fault. The best thing to do is to solve the ram issue first and address any remaining issues afterward.
