How to mount my non VESA Samsung monitor?
Dora1008
Commendable
Feb 24, 2016
I bought a monitor arm for my monitor. But I suddenly found that there is no VESA hole on the back of my monitor!! Is there any solution for that? Or I might return it
Just return it and get a dell ultrasharp, 100% of those have vesa mounts (most are 100mm)
You really should have checked your manual and monitor spec sheet though, it's usually written right there if it has mount support or not
I would not recommend this for two reasons:
1) It ugly as hell... even a chinese crested looks great in comparison (and it's often considered the ugliest dog in the world)
2) You can cause severe damage to the monitor, either stress fractures/bending due to pressure on weak areas, or increased likelihood of fall damage.
Use at your own risk, but it's usually better just to get a proper monitor with mounting capabilities.
