Question How to overclock ram on b450m? I have a CORSAIR DOMINATOR PLATINUM 16GB 3000MHz C15 Memory Kit (CMD16GX4M2B3000C15)
janneauclaude
Commendable
Feb 4, 2017
75
Hello guys i am new to this and i would like to learn how i can get my ram to 3200mhz. Should i just directly set the xmp to 2933mhz? Or is there anyway i can let it work
Motherboards sporting AMD's B450 chipset are available from several different motherboard manufacturers a B450M indicates it is a Micro-ATX Form Factor model.
If left on [Auto] it runs at:
SPD Latency: 15-15-15-36
SPD Speed: 2133MHz
SPD Voltage: 1.2V
One normally does not buy 3000MHz memory to run it at 3200MHz. What to set in the BIOS depends on the motherboard you have, which you have not listed. B450M is a partial name for a multitude of different models.
SPD Speed: 2133MHz
SPD Voltage: 1.2V
okay so how can i make it run at 3000mhz? U have a gigabyte b450m d3sh
