S Strike7100 Reputable Jul 8, 2015 71 0 4,630 Jul 9, 2015 #1 I want to spend around 50-150 pounds on the MOBO but I do not know the difference between each one. Also I do not mind if it is a smaller MOBO or normal sized.
Solution gskill support Jul 10, 2015 Essentially, they are all very good boards, though they have some differences that you should look at to see if you need/prefer one over the other. But as far as quality, overclocking, stability, and such, they will all get the job done nicely.
gskill support Splendid Feb 27, 2012 2,932 112 24,390 Jul 9, 2015 #2 Where do you shop for parts? You want to look into Z97 motherboards for that CPU. Upvote 0 Downvote
S Strike7100 Reputable Jul 8, 2015 71 0 4,630 Jul 9, 2015 #3 gskill support : Where do you shop for parts? You want to look into Z97 motherboards for that CPU. Amazon.co.uk, Scan.co.uk, anywhere in the UK really 😀 Upvote 0 Downvote
gskill support Splendid Feb 27, 2012 2,932 112 24,390 Jul 9, 2015 #4 http://www.amazon.co.uk/ASUSTEK-COMPUTER-Z97-PRO-GAMER-SATA6GB/dp/B00OK6Q1D0/ref=sr_1_6?ie=UTF8&qid=1436480894&sr=8-6&keywords=asus+z97 Upvote 0 Downvote
S Strike7100 Reputable Jul 8, 2015 71 0 4,630 Jul 9, 2015 #5 gskill support : http://www.amazon.co.uk/ASUSTEK-COMPUTER-Z97-PRO-GAMER-SATA6GB/dp/B00OK6Q1D0/ref=sr_1_6?ie=UTF8&qid=1436480894&sr=8-6&keywords=asus+z97 What would be a good M-itx or mini itx option? Upvote 0 Downvote
gskill support Splendid Feb 27, 2012 2,932 112 24,390 Jul 9, 2015 #6 Top 2 Mini ITX: http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=asus+z97+miniitx Top 3 Micro ATX: http://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=asus+z97+matx&rh=i%3Aaps%2Ck%3Aasus+z97+matx Upvote 0 Downvote
S Strike7100 Reputable Jul 8, 2015 71 0 4,630 Jul 9, 2015 #7 gskill support : Top 2 Mini ITX: http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=asus+z97+miniitx Top 3 Micro ATX: http://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=asus+z97+matx&rh=i%3Aaps%2Ck%3Aasus+z97+matx And all of these do the same job right? Upvote 0 Downvote
gskill support Splendid Feb 27, 2012 2,932 112 24,390 Jul 10, 2015 Solution #8 Essentially, they are all very good boards, though they have some differences that you should look at to see if you need/prefer one over the other. But as far as quality, overclocking, stability, and such, they will all get the job done nicely. Upvote 0 Downvote Solution
logainofhades Titan Moderator Apr 27, 2009 39,374 4,635 143,290 Jul 10, 2015 #9 THG recommended motherboard. PCPartPicker part list / Price breakdown by merchant Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard (£99.98 @ Amazon UK) Total: £99.98 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2015-07-10 20:07 BST+0100 Upvote 0 Downvote
S sora Splendid Oct 30, 2013 7,812 0 31,460 Jul 10, 2015 #10 Yes, those three cases would do the same job. Upvote 0 Downvote
