umeramerkhan :
ameyer75 :
What you're reading is just a description. Any normal mic will work for that. Generally speaking, you plug it into the port on the front or top of your computer. Otherwise, there's more than likely a port on the back of your computer that plugs directly into your motherboard.
i don't have any mic, i am trying to use handfree. Will this work and if so where should i plug in my handfree, mic jack or headphone jack as they are two jacks
What's the standard you're using on the handsfree device? Bluetooth? Does it come with a bluetooth dongle, or does it connect straight to the computer. In fact, if you haven't figured it out, link me the product you're trying to connect to your computer.
