You would use the two PCIe 6+2 cables. Mount the GPU into the computer, then connect the one PCIe power cable with the two loose nubs (make sure to set those in below the 6 so they mount properly) and for the 6 pin connector just leave the extra two nubs loose and you are off to the races!
The card has two PCIe power connectors one 6 pin and one 8 pin. Your PSU has 2 x 6+2 PCI power connectors and you need to insert one 6 pin part in the 6 pin on the card and both the 6 pin and 2 pin in the 8 pin on the card together.
