[SOLVED] How to prevent program from running as an Administrator?
The Electro Machine
Commendable
BANNED
Jan 28, 2021
162
I have this very old piece of software [from 2003] than for not apparent runs itself as an Administrator;. And this I know because I can see it under the
Task Manager > Details > Elevated
And [ong story short] apparently this causes problems with some other programs trying to cooperate with it
So my question is: how do I stop this software from being elevated?
I have tried going to its EXE and turning for it ON & OFF [as it was set to OFF in the first place] the
Properties > Compatibility > Settings > Run this program as an administrator
option, but it did not reset the EXE. Also renaming the EXE did not foll the operating system
I am using Windows 10 Enterprise 20H2 19042.746
You might be able to use Powershell to launch Sony Sound Forge "non-elevated".
Reference:
https://serverfault.com/questions/782824/start-process-as-normal-user-powershell/782852
Read through the full posting.
There are other similar links to be found but most focus on elevating versus non-elevating.
Basically just launch Powershell as an admin on your system.
Copy and paste in the applicable cmdlet at the PS> prompt. You will need to use the Sony app's .exe name. (versus "sample.exe"). Hit Enter.
Could be a different path name as well.
Not something I have worked with (full disclosure) but it may be viable and worth a try.
Be certain (as you always should be doing) that all important data, files, etc. are all backed up, proven recoverable, and readable.
But...
I need run Sound Forge non-elavated so that it is on the same level as 3 other non-elavated pieces of software that I use for audio related work. [I did try run the rest of programs as elevated- and it worked. But there were drawback to that opposite approach that make that in overall made not really usuable to me]. So in order to send a file from some other software to Sound Forge with a keyboard shortcut - I would need to somehow incorporate that PowerShell into this shortcut; or run Sound Forge and never close it?
And I am afraid this might not work - i.e. I will successful run Sound Forge non-elavated with PS which will get me nowhere as I will fail in incorporating that into my workflow
So before I indulge myself in PowerShell- does anyone else have some other ideas?
For example
I need to send a selected file from the non-elavated FreeCommander to elevated Sound Forge- which is impossible. And so: I need that process of sending to open Sound Forge in a non-elevated way [evoked from FreeCommander]
I do not want to just plain open Sound Forge in a non-elevated way- because I would still need then to go to FreeCommander to the selected file and execute the sending of it to Sound Forge. That would totally disrupt my workflow thus be counterproductive
I have finally found a working solution - in form of a Registry hack:
Code:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers]
"C:\\Program Files (x86)\\Sony\\Sound Forge 7.0\\forge70.exe"="RUNASINVOKER"
It works- a least on my Windows 10 and for this particular program
