[SOLVED] How to re-enable WiFi that was disabled through a physical key
manasan3010
22
I have a F8 key in my keyboard and I disabled my WiFi using it and now that key is broken and not working SO is there any way to enable WiFi that was disabled using that F8 key back using any software hack?
You'll have to replace the keyboard to get that functionality back. An external keyboard may not have the necessary "fn" key. You'll not be able to toggle the wireless adapter as long as that key doesn't work.
Bring up the onscreen keyboard and press the Fn key in the lower left corner. They you can click on the F8 key in that.
The problem is my HP G62 laptop is a little different and the F8 key is a special key and it's regular functionality itself is to control the WiFi and you press the Fn key to get the functionality of F8 in Softwares, So on-screen keyboard didn't work for me.
