Most TP Link PCI cards have the thick black plastic antennas, which you rotate (while holding the point nearest the base) to unscrew.
If it's a card with a cable running to a moveable antenna, just snip the wire if it's truly broken.
Why not just remove the card from the PCIe slot on your motherboard & remove it that way? The antennas should fit through the expansion slot...
