L Lawwill52 Reputable Dec 15, 2014 2 0 4,510 Dec 15, 2014 #1 I cannot remove the write-protection from my 16Gb USB2.0 flash drive is there a quick way to do this
Xyos Distinguished Oct 5, 2009 631 1 19,360 Dec 15, 2014 #2 In my computer if you right click it, go to properties-security, then set yourself to have full control of the drive. Apply, than ok. Upvote 0 Downvote
M mbarnes86 Splendid Sep 16, 2010 3,839 7 26,965 Dec 15, 2014 #3 Hi Most important Can you copy the files off this usb memory stick? If so copy off any files you want to keep What format? NTFS Fat 32 ExFat See if ruffus or similar programs can re partition & format usb disk If not device probably faulty If this succeeds use h2testw to test the usb disk for hardware faults Regards Mike Barnes Upvote 0 Downvote
