How to RMA a S2460 with ATX meltdown
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.tyan (More info?)
I have been very happy with the S2460- until I finally experienced the
dreaded ATX meltdown recently. I'd like to know if others have had
success getting an in-warranty RMA for this common problem or if there
are pitfalls in the process. I'm sure there have been quite a few ppl
in this position before expiration of the 3yr warranty.
TIA.
Also wondering if anyone has had success RMAing PSU's damaged in these
meltdowns or if we are sol? I lost an Antec True550. Both have 3 yr
warranties, but I can just imagine the finger pointing/blame-game I'm
going to get when I make the calls...
Once again, thanks for your experiences/ideas.
It depends where you live as to who you RMA it to. Tyan Europe in Germany
provide a no quibbles RMA service for this although aren't helpful re PSUs.
It is possible to buy replacement connectors/terminals to repair them
though, here's one supplier in the UK
http://www.kustompcs.co.uk/acatalog/Kustom_PCs_Shop_Switches_and_Molex_66.html
Good luck!
Paul
"Curious George" <CG@email.net> wrote in message
news:ng05d0d83i96l6gdef9t51qcikle2m91sh@4ax.com...
i just rmad an antec truepower 550watt via the retailer - ebuyer - the psu
was just over a year old when it died [giving no power so mobo ok] it was
collected from my home & replacement delivered,
similarly my first s2460 died at 3 months old taking 1 cpu with it - both i
had replaced by the retailer
retailers don't have the same need to point fingers as manufacturers
dr ratt
Excuse my ignorance, but may I ask whether I should be worried about this
problem with my S2466? What is it?
Thanks...
JL
>Thanks...
>JL
No. It was fixed for MPX boards. Also the Thunder S2462 doesn't have
the problem either due to the proprietary PSU. The S2460 ATX power
configuration is not an approved solution by AMD. The S2466 is.
http://students.washington.edu/vladis/atx_burn/
http://forums.2cpu.com/showthread.php?s=1cfd21099cbc53208d6d6e566559ffdc&threadid=35024&highlight=tiger+mp+atx+connector
http://forums.2cpu.com/showthread.php?s=127f61b1142c9f8daa4a308ada5e96e5&threadid=13703
http://forums.2cpu.com/showthread.php?s=&threadid=28746
http://forums.silentpcreview.com/viewtopic.php?t=4457
etc...
Thanks everyone for the follow-up. Will give RMA a try.
What does the Thunder S2462 ATX power configuration entail?. I just
picked up one of these boards and was planning to use an Enermax
EPS12v PSU with an ATX-GES convertor cable. Is that setup OK or am I
looking at a meltdown problem?
falcon
>>Thanks...
>>JL
>etc...
No meltdown problems with 2462, only 2460, cause it doesn't have an
extra doodad, just the standard ATX connector. Too much flowing through
too little. The 2462, on the other hand, has its handy ATX-GES
connection, bypassing that problem?
Where did you get your ATX-GES convertor from? I want one, but am having
real difficulty tracking one down in Britain. Fancy buying an extra one
and mailing it to me? I would, of course, reimburse you!
Cheers
Mark
"fakcon" <Qmfaile@msn.com> wrote in message
news:0qtme0pdjuijos9vjmbg23g560hgm9m8vg@4ax.com...
> falcon
iirc, the s2462 is the k7 thunder. this uses wtx format for power therefore
you will need the cable to convert to wtx rather than the one mentioned
http://www.baber.com/baber/products/power_supply_connectors.htm
the one above the atxges on this ad is the cable needed
[ad is 1st in google list, no idea how good the store is]
dr ratt
this
> >>Thanks...
> >>JL
readid=13703
> >etc...
>>falcon
> dr ratt
Dr Ratt, sorry, but I think you do not recall correctly. Yes, the s2462
is the K7 thunder, but no, it takes an ATX-GES NOT WTX. Check the tyan site:
http://www.tyan.com/support/html/r_s2462.html
All the recommended PSUs are ATX-GES.
Oh dear.
I just bought an s2462 -- and everything needed for building it up.
I was planning on using an atx psu -- with s2462 acceptable output
ratings, and all -- and using 4 to 8, and 20 to 24 pin adapters.
Anyone know if I can, in turn, adapt the atx to eps adapted psu to
atxges?
I know I can get the adapters, just don't know if this is "kosher", or
whether the board will post.
I'm trying to get all the adapters before the stuff arrives via mail
order, and I need to test the board before the "as is" warrenty runs
out. Don't have any sort of testing equipment -- just need to hook
it up, and see if it posts.
Regards,
Bryan
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
Previously bhoover <bhoover@wecs-dot-com.no-spam.invalid> wrote:
> Oh dear.
> atxges?
It is not quite that simple. 4->8 does not give you the power of
8. Far from it. 20->24 is also a problem, the 20 only have one (!) 12V
line, the 24 has 2 these. That is why you can make an EPS->ATX
adapter, but not easily the other way round. EPS<->GES is more or less
possible.
Have a look at this image here:
http://www.enermax.com.tw/851atxgesconnector.htm
This is EPS to ATX GES by Enermax. The PSU is on the bottom.
No real problem here. The following is EPS to ATX 12V:
http://www.enermax.com.tw/851atx12vconnector.htm
The details are in the manual available here:
http://www.enermax.com.tw/download/EPS_12V_English.pdf
Note that EPS has 4*12V in the extra connector and
2*12V in the 24 pin connector. With an ATX12V you have
2*12V in the 4 pin connector and a single 12V in the
20 pin connector. So your are doubling the current load
and hence put 4 times the termal load on the cables. and
connectors on the ATX side. Not a good Idea! Soldering the
connections would be a lot better but still problematic.
I would say that you should at least use two additional
individual 12V lines from the peripherial connectors.
And why not het an EPS PSU or e.g. an Enermax 3in1 in the first
place?
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
> possible.
Yeah, I figured the adapters would take care of all that, and go from there
as long as it was backed by a strong, and stable enough power supply.
Poof!
Plus, Tyan said there's some extra signling or feedback the board gets from
the atxges -- hopefully, if so, that's in the eps as well, or.....
> place?
it's covered in the Enermax supply.
Because, funny you should mention Enermax. I bought one in the wee hours
this morning after running across their line of supplies on a company out of
Japan's site. That listing sold me on good power supplies -- plus the bad
review I read about the one I had bought for 29 bucks -- it's 580w so may
put it in my old atx. I searched for the best price, and came around to
this nifty unit:
http://store.yahoo.com/directron/eg465pvefm24p.html
It's on the way to me as we speak. And I've got a new retail jones in terms
of power supplies. These things are cool (pardon pun). Smooth, clean,
stable power. Feel like Tim the tool man -- rawww, rawww, rawww (or
something like that).
Bryan
> Arno
What is a poet? An unhappy man who hides deep anguish in his heart, but
whose lips are so formed that when the sigh and cry pass through them, it
sounds like lovely music. - (Soren Kierkegaard - Either/Or)
http://www.wecs.com/content.htm
This signature file is generated by Pick-a-Tag !
Written by Jeroen van Vaarsel
http://www.google.com/search?hl=en&ie=ISO-8859-1&q=pick-a-tag
> this nifty unit:
I have one of the above running in a dual-opteron. Well designed
techology. Enermax seems generally pretty good. Not the most quiet,
but in reviews they regularly outperform their maximum rating, while
others fold sometimes as low as with 80% of max rating and are
sometimes dead after this load.
Arno
Arno Wagner <me@privacy.net> wrote in message news:<2p65fcFgt45jU2@uni-berlin.de>...
Ah-ooo-ah.
I have not noticed that it is very noisy or anything. But that might
be because the cpu fans I've got -- vantec -- are quite loud, very
high rpm (rated at 6800rpm, and the Tyan board monitor (and the bios)
was saying 7700 or there abouts!) 'til I grabbed a copy of SpeedFan
and slowed 'em down.
Adjusting the fan speed helps control case vibrations, hum, howelling,
and all that according to your own personal accoustics tollorances
shall we say. Of course, I realize temperature is the most important
thing, but my fans were running so high, there was room to spare in
that department -- I wasn't gaining all that much by letting them run
fast.
Temps are still not all that low, so I'd probably do well to get
another case fan or two -- two in the back right now. Monitoring is
showing the psu fan running around 1400 rpm. CPU's are around 42, and
VRM1 is at 46 -- I wonder if that's too high. I thought it was kind
of funny how VRM1 is placed right next to cpu0, seeing as how vrm1
puts out a good measure of heat.
So anyway, I got the s2462 up and running without a hitch. Again,
though, probably need more cool.
Bryan
> Arno
