How to separate headphone audio and speaker audio
Hello
So what i want to do is separate my headphone audio from my speaker audio.
I have an audio input in the back of my pc where my subwoofer and speakers a plugged into.
In the front I have my headphones.
But in windows 10 sound options they are all the same device "speaker" but i would like my headphones to have enabled Windows Sonic for headphones, but I dont want it on my speakers, as my sub can only be activate if i have a 5.1 speaker setup. But Windows Sonic for headphones disables this.
I have attached a file so you can see what i mean, hopefully. It is in Danish but i made some translations in red for you guys
https://imgur.com/a/XI1Lg4y
if someone still need this i found the solution
first of all open Realtek HD Audio Manager,if you can't find it in search open Task Manager > Startup > right click on Realtek HD Audio Manager > Open File Location > run RAVCpl64.exe.
Then click device advanced settings at top right side in Realtek HD Audio Manager - http://prntscr.com/li2q6p
Then check "Make internal and external output devices playback two different audio streams simultaneusly" -
http://prntscr.com/li2qb1
Result:
Finally we got speaker and headphone outputs
http://prntscr.com/li2qg7
http://prntscr.com/li2qkn
