How to set up fans on top of a radiator for exhaust
tgtony
4
Hello there. I just bought a new rig and have been setting it up this afternoon when I ran into a slight problem. I bought a 750d with a h100i corsair cooling system which both are great but I the snag I hit was when I attempted to mount the fans on top of the radiator in a pull formation so as to exhaust through the top of the computer. For the life of me, I can not figure out the easiest way to screw in the fans and radiator attached to the top of the case. Its very awkward to screw in the fan to the radiator while balancing it and would like to know if I am just dumb and have been doing it the wrong way.. Any tips on how to properly align and secure fans on top of the radiator so they can pull air from inside the case through the rad and then out the top?
Thanks!
You could screw the fans in two spots each onto your case (with small fan screws). Then hold the radiator up against the fans and use the long screws to reach the radiator holes then screw them in the remaining holes. Now just remove the two screws from each fan (the ones you used to keep them in place), and use the long screws to screw into the radiator. Now you have your fans in pull.
