It sounds like you need to format it:
Applications --> Utilities --> Disk Utility
Select the disk from the left. Click the 'Erase' tab. Select your format options and begin. Be sure to consider if you'll need to mount this drive on computers running different operating systems. (i.e. Windows?)
