Hello all,
Noob questions, please bear with me.
First time builder, not very familiar (not much at all) with technical aspects of electronics either. I have been trying to research case fans but haven't got a definitive answer for my problem which is regarding putting 2 case fans 120mm on top + replacing the rear end one. I am mostly confused about the headers and how to split fans into limited number of headers, I am aware of the different pin setups.
The B550 tomahawk comes with 2 ARGB 3A 5v 3pin headers and 2x RGB 3A 4pin headers.
The H500 comes with 2 140mm ARGB fans and apparently with a 1 to 3 splitter, as I understand the other end goes to the header and it splits into 3 fans, so this would occupy one of the ARGB headers for the 2 fans am I correct? Now I don't know if this would exceed the amperage for the one header as I don't see any mention what's the amperage of the fans?
The H500 comes with 2x 140mm ARGB fans on the front and one in the back. I thought of putting 3 identical 120mm RGB fans, 2 on top and replace the one in the rear, all 3 of them as exhaust and have the 2 front fans be intake.
The question is:
Thank you so much in advance, appreciate all the work and helpers.
https://www.amazon.de/-/en/Liwintin...replacementKeywords=1+bis+rgb+splitter&sr=8-5
https://www.amazon.de/-/en/Enermax-120-T-B-Pack-Illuminated/dp/B07S7STV2C/ref=sr_1_3?crid=1BEYWO2JJTR0T&dchild=1&keywords=enermax+tb+rgb&qid=1606520132&sprefix=enermax+tb,aps,185&sr=8-3
https://www.amazon.de/-/en/CO-9050071-WW-Corsair-Computer-Fan/dp/B075VDGSJ8/ref=sr_1_3?dchild=1&keywords=120+mm+corsair+rgb+lüfter&qid=1606519935&sr=8-3
My setup:
The question is:
- Are all 120mm fans universal and compatible for the case and motherboard?
- Do I use a 4pin 1 to 3 RGB splitters (such as in the link below for example) to handle the fans as I have only 2 RGB headers?
- As I check fans, I don't really see the amperage of the fans in the specifications for any of the fans I'm checking? Will they generally undercut the 3A figures if I combine 3 fans into a RGB header so I'm safe for sure?
- What fans should I get, I want something that would be esthetically nice, not insanely expensive though, I was looking at Enermax T.B rgb or Corsair LL120 RGB, or something that you suggest? (Links below)
- Is there any better setup way? I've seen some of these external controllers that can be used as some sort of connectors for the rgb fans
My setup:
GPU | RTX TUF 3080 |
CPU | Ryzen 9 5900x |
Cooler | Dark rock pro 4 |
Motherboard | B550 Tomahawk |
PSU | MSI MPG A850GF 850W Gold 80+ Fully Modular ATX PSU |
SSD | Samsung MZ-V7E500BW 970 EVO 500GB NVMe M.2 Internal SSD Black |
Memory | G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory |
Case | Cooler Master MasterCase H500 ARGB |
