Okay, so I bought a sapphire vapor-x 7970GHZ 3GB. I CANNOT run 3+1 eyefinity with this card and I need to figure out how (Used to gaming with an extended 4th screen on top). Would snapping up a $29.99 AMD card and putting it my system allow me to do this? If not, how can I complete this task!
I am currently running 3x1 eyefinity with monitors connected to DVI 1 (Dual Link DVI) DVI 2 (Single Link DVI), and then the 3rd screen hooked to my single displayport via active adapter. I only have a single displayport and eyefinity runs like a dream. However, I have 4 screens and want a 3x1+1 setup.
HOWEVER, if I can't run 4 screens on a single GPU (which is balls) can I add a cheaper AMD card to the mix and still get 3+1!?
Thanks
Thanks
